Someone already used Ventuz 3.08 with Deltacast HD (5.11)?
The DVI Board workes fine but from the SDI Board i only get´s an error message (input sensing failed)
Thx
mmahoni
Ventuz 3.08 and Deltacast HD
Re: Ventuz 3.08 and Deltacast HD
Which Deltacast SDI board do you use?
And what are you doing exactly?
We use DELTA-hd-e 20.
What i´m doing is:
deinstall of ventuz 3.07.01
deinstall of the hd-e20 and the dvi-e20 in devicemanager
install of the new deltacast 5.11 drivers
install of ventuz 3.08
thx
mm
What i´m doing is:
thx
mm
we also just checked the new Ventuz 3.08 version with a Deltacast HDe 22 Key and it works fine here.
Didn't check the input though, but we also didn't get a error message like you.
Are you sure you connected the right inpit format to it?
best regards,
Oliver
best regards,
Oliver
I can confirm that there is a problem with the combination of the Deltacast 5.11 driver and Ventuz 3.08 with the DELTA-hd-e 10 card when sending standard def at 50hz. I get a white screen.
Rolling back to Deltacast 5.08 and Ventuz 3.07 fixes the issues. I have not been able to test with HD-SDI signal, only SDI standard def signal.
Luckily my scene works ok with rolling back to 3.07 as currently on site and needing video input!!
my input-signal was 50hz too (but HD 720p).
Unfortunately I didn´t test other resolutions or framerates.
I made a rollback to 3.07 too...
White screen here with hd-sdi signal on DELTA-hd e10 too.
Ventuz 3.08...
Argh..!
Robert
Ventuz 3.08...
Argh..!
Robert
Fixed in Ventuz 3.08.01 !!!
