Count images in folder
I have a project where I want to display a number of images that have been uploaded to a remote folder. The quantity of images will vary and I thought that there must be a way to have each image displayed on an individual polygon, although at present not certain the best way to achieve this. Ideas? I thought somehow of using multiple polygons arranged with an 'Arrange' node where each texture gets its file from an array obtained by somehow building an XML list of names in the folder.
In the course of my experiments I thought that it would be a good idea to start by counting somehow how many files in that folder. The DIR node has an AutoUpdate tick mark, but no matter what it is set at, does not update the file list of new jpgs added to the folder. Can it only detect the content of an image changing rather then a file being added or subtracted?
Is my idea only achievable via using a Script?
Re: Count images in folder
Hey I do it always like that.
I build a Hierarchy container that contains a Rectangle a Color and a Texture loader. Each container also has a Stringsplitter node that gets the Current Element count from a ContainerInfo node and exposes the Input.
At the root level I read a Directory with a Directory node that gives me a Result string inlcuding all Pictures seperated by linebreaks (It will be seperated by commas in Ventuz4) so I pipe the result string in all the containers on the input of the StringSplitter so that each StringSplitter get the image based on the ContainerNameIndex.
On the root level I use another StringSplitter to get the Count of the Directory ResultString, each container blocks itself if his own ContainerNameIndex is bigger than the image count.
Cherio!
Cherio!
Hi Daniel,
Thanks for your ideas on this. I was 80% there when I read your reply. My idea was working but not as expandable as yours using the container information. Modified mine to work as per your idea.
I still think that the DIR node is not functioning as the book says. Have a look at my zip file where I have a folder of images and a VZA. According to the book the DIR should auto update on the contents of the folder. It does not detect an image bing moved in or out of the folder, and I am unable to have it detect if an image is overwritten with new content. Also the sort by date doesnt seem to correspond to either the 'date modified' or 'date created' as shown by Windows, so not certain what Ventuz is sorting on. See if you get the same results.
hi daniel
i can agree with peter! the dir node is not updating if there is any change in the folder! you have to dectivate and reactivate the auto update function!
and the dir node and textsplitter: i thoght thats my idear....but good to know, that you do it same way
Your are right the AutoUpdate property is not doing what it supposed to. I wrote a ticket in the interal wiki.
May be it is simpler to write a simple C# Script which get the directory path in.
and with wildcardusing System.IO;
string[] filePaths = Directory.GetFiles(@"c:\MyDir\");
// returns:
// "c:\MyDir\my-car.BMP"
// "c:\MyDir\my-house.jpg"
When you use the Pro Version, sure.string[] filePaths = Directory.GetFiles(@"c:\MyDir\", "*.bmp");
// returns:
Hi Peter
Just wondering about the background to the initial post? What's the plan for the scene?
I understand the basic idea, but do you want to change the image when new ones are added? is that why you need to keep track of the number of files in the folder?
.....every time an image is added to the folder, you want it to add to the scene along with all the others which are already present? or do you want new ones to appear on polygons which in turn pushes old ones out? ( so you only ever have say 6 rectangles at any one time in the scene and the images simply change)
Don't want to complicate things
but the more understanding the more tailored the answer can be
The way i see it so far is using an array in a script as Joschy says or a list in a script.
Hi Chris,
At the moment its at the idea stage after demoing to a client. They want to be able to take a load of photos that get automatically uploaded to the 'cloud' from a number of mobile phones at an exhibition. Haven't really thought much more about how to display or had a brief on the number of images to be kept on screen. Only at early stage with C# so may need to outsource some of that.
I'm also at the early stages of C#, but I like a challenge
The result I came up with was using a List in a script. Convert the list to an array and pipe out the array into a string indexer.
can also add an int output from the script which gets the number of files from the "List.Count" command.
Seems to work ok, plus you can order the results in date created order (something i'm still trying to workout
) which will be good for only showing newest pics
sure you thought of this one but, also a good idea to link the rectangle sizes to the image node sizes and normalize
phones take many different pic sizes...this way the geometry resizes on the fly
to all: would that be an efficient way to do it??
chris
chris
now im looking at it the DIR node does all of that!
told you i like a challenge!
now where was I....oh yes....cup of tea
