Hey guys,
I have a feature request, basically, when you zoom around in the Logic View, and things get crazy, meaning 15 States, 52 Connections, you just get confused.
an Isolation mode would be awesome. Select 3, 4 or how many ever states you need, right click, select isolation mode, and all other states and connections become semi transparent.
I made a few pictures which demonstrate how this would work.
Also, in isolation mode you hide all other slices (connection between states), you could then be able to go back to the Timeline view and be able to switch between slices the way you're used, for easy usage.
what do you guys think?
-Alex
Isolation Mode for Logic View
Re: Isolation Mode for Logic View
Hi
Thank you for your suggestion we will add your request to out internal wiki and discuss the feature for future versions.
Cheers!
Cheers!
Thats what I call abuse of the "connect all to all" function!
anyway thank you for your concern. We will take this into account.
Cheers!
Cheers!
