What kind of cpu for Ventuz is the best and stable performance ?
I use the Intel core series(i7, 2600K) in my developing, however my client always set up a group of Intel dual xeon.so many logic node(timer, counter which is related to cpu clock) will work bad,including the animation line runs faster or slower either : (
about the CPU type
Re: about the CPU type
Hey allen hyoga,
The V-Boxes are using the Intel Xeon w3550.
Since we use mostly V-Boxes here - this is the most "tested" CPU you can actually get.
cheers!
cheers!
iotek
So would you say that the Xeons are more stable than i7/i5 processors?
if yes, is it also to do with ECC memory being a better option?
cheers
chris
cheers
chris
No,
the only thing I can say is that the Xeon is what we actually use. And surely this will change with technical progression.
I cannot tell if i5/i7 is more or less stable but i would GUESS that there should not be any difference - anyways its not specificly tested so dont nail me down on this. Same for ECC - not tested but might be useful.
What I can say is Ventuz benefits from a strong CPU as every programm does but this will mostly show up when decoding big- or lots of videos.
cheers!
cheers!
We have only been working with I7 based systems shortly after they came out. We have several dozens of them and we never had a problem with them. The CPU is not the indicator for a stable system IMHO anyway. It is more the combination of parts that you combine. The mainboard seems to be the crucial factor. Use proper workstation-class motherboards, preferably from ASUS. We had sever problems with others. RAM does not need to be ECC. We never use it. But you need quality RAM that has been certified by the mainboard manufacturer for your specific board. Then you need to get a decent power supply, etc etc. It takes time to find and test a good combination of parts that form a really stable system you can trust. As it always has been: Cheap parts equal cheap system.
which btw gives me the perfect opportunity to make an advertisement for the V-BOXES from XI MACHINES
Check out the V-Boxes
this is what you get for best performance an stability
cheers!
cheers!
Well played Oliver. Well played ...
