Each video signal will recive with an RTSP stream. It nessesary to use RTSP streams because some Applications need the video signal to make some realtime color corrections on it. I knew that is also possible in Ventuz using a HLSL Shader but in this case it would be enough.
I found some Solution using some Virtual Devices Mappers who maps my RTSP Stream with VLC to a Virtual Device.
Is there any possible solution without remapping the RTSP Stream to an Virtual Device to get the RTSP Stream into Ventuz? Because the Virtual Device solution wasn't performant enough for more than 2 streams.
My system works with 2x GTX 580, SSD RAID and an i7 running at ~ 3.8 GHZ
So it should be fast enough to Stream more than 2 ~1024*567 Streams into Ventuz.
Some Pictures out of my Ventuz Project are Attached
The Color Correction Before the Video are streamed to Ventuz is onyl to normalise the luma in order to got the same result in Ventuz. So basicly Everything you see is Created in Ventuz directly.
Movie showing some Audio to Motion expression found here
http://postwendend.com/fh/tanz/tanzen.wmv
So i hope there is a Solution for my problem.
PS How much would it cost to create a Ventuz PRO file out of my PLE?
