Hi All,
I want to show 3d full HD side by side videos (3840x1080) on 3D compatible TVs using the 3D Vision driver.
Is this possible to do it with Ventuz 3 or do I need a multiplexer that mix two DVI outputs in one 1.4a HDMI?
Gabriele
do I need a multiplexer?
Re: do I need a multiplexer?
hi gabriele
i never test it but i would say it depends on your display! you need to make a 2 camera stereoskobic setup side by side and a project 3840*1080 on one output! if the edid of your monitor supports this resolution on the hdmi input it should work! just switch your screen to 3d side by side
chriss
chriss
