I'm currently working with the .NET remoting interface in an external C# program.
Can anyone give me a short sample on how to use the callback functions to connect functions of an external program to events invoked by Ventuz?
I knew this already was here somewhere in the forum, but I can't find it anymore.
Thank you!
.NET Remoting and Callbacks
Re: .NET Remoting and Callbacks
With Ventuz Remoting 2 it would look like this:
Use the Externals property on your RemoteScene instance to get the IExternalCollection.
See the Ventuz Remoting API Help for further details.
private void SetupEvents(IExternalCollection extColl)
if ( extColl != null )
// get Event names for subscribtion
IEnumerator<IExternal> extEnum = extColl.GetEnumerator();
while ( extEnum.MoveNext() )
IExternal ext = extEnum.Current;
// subscribe to externalized events
if ( ext is IExternalEvent )
((IExternalEvent)ext).Callback += new ExternalEventHandler(Event_Callback);
Console.WriteLine("-- Subscribed to Event {0}", ((IExternalEvent)ext).Name);
hi, Karol
While I was finding "CallBack" on this forum, I found your post.
btw,
What is the "Event_Callback" above this code?
How can I Make it?
thanks
divin
btw,
How can I Make it?
thanks
divin
'Event_Callback' is the callback method which is called if an event occurs :
Could be something like this:
private void Event_Callback(IExternalEvent exernal, ulong time, int arg)
Console.WriteLine("-=# EVENT_CALLBACK #=-");
lock ( this.eventQ )
// fill Q. to process it in UpdateEvents()
this.eventQ.Enqueue(string.Format("Event #{0}: {1} - Args = {2}\r\n", ++evCount, exernal.Name, arg));
this.haveNewEvents = true;
if ( this.tbEvents.InvokeRequired )
// cross-thread: so invoke on GUI-Thread
this.tbEvents.Invoke(new UpdateEventText(this.UpdateEvents));
else
this.UpdateEvents();
