Imagine you have 100 objects that each have 10 properties. You want to have access to all these objects in your scene. 2 of the properties change frequently (group A), 3 once in a while (group B) and 5 rarely change (group C). I'd like to get your advice on the best way to push this data into a scene. Here are some approaches:
1. Push a JSON array that contains 100 nodes with 10 properties.
2. Push 3 JSON arrays that each contain 100 node but with the 3 different properties groups (A, B and C).
3. Push 10 JSON arrays, one for each property.
In these 3 scenarios, accessing a specific object would be done using the JSON Parser node: 100 Hierarchy Containers (named 0-99) would contain a JSON Parser that uses the Container Info node's NameIndex to extract its JSON object from the array. Back to the 3 scenarios:
1. One JSON Parser extracts all properties.
2. 3 JSON Parsers would extract the 3 groups of properties.
3. 10 JSON Parsers would extract one property each.
Each scenario seems to have its advantages and disadvantages:
1. Advantages: One JSON Parser for all properties.
Disadvantages: All JSON data is sent if any data changes.
2. Advantages: Far less data sent when data changes, mostly group A data gets updated which is 20% of the data.
Disadvantages: More logic nodes.
3. Advantages: Only the data that changes gets sent.
Disadvantages: large amount of logic nodes.
It would seem that the second approach would probably be the most efficient at handling the data but maybe there are some areas where Ventuz is more efficient. For example, handling incoming data might be faster than dealing with large amount of nodes, making scenario 1 more attractive than scenario 3.
Some questions:
1. Would it be better to skip the JSON Parser and create 100 groups in Scene Data, with 10 properties each, and push the data directly instead of using JSON?
2. Sticking with the JSON approach, is there a way to have the data parsed asynchronously? Unfortunately the last project I did still used CLI to push the data instead of Remoting so that could've been one of the reasons I experienced some dropped frames when pushing updated data.
Thanks for any suggestions you might have.
Etienne Laneville
Best way to push data into a scene
Re: Best way to push data into a scene
Hi Etienne,
just curious - which path did you finally choose?
#2.
All my data is JSON blocks delimited by ";" so the scene receives a long string and uses a String Splitter to break the string into a string array. Each object gets its own JSON message from the string array and parses the JSON.
Happy to discuss more.
u-double-u
What about Excel?
The same applies to any data source. You want to break up the data into groups based on their update frequency. If your data is in Excel, you can break it into separate sheets to achieve this. The objective is to minimize the data parsing time for Ventuz so the better your data is organized, the less data Ventuz will have to parse when it updates.
u-double-u
Did you test it? To me, 100 objects diesnt seem that much..
It depends what the 100 objects are used for in the scene, how many properties they have, how often they change, what they control. Imagine 100 objects setting an image, text, and triggering animations 2 times per second.
