am I the last one to find out that Ventuz 6.3.3 does not (seems to not) load info from a .xlsx file but from a .xls ?
Which I had thought to be an older format...
cheers.
XLS v.s. XLSX
Re: XLS v.s. XLSX
Hi u-double-u,
You are the first one!
Xlsx files generally works.
So there must be something special about your table.
Re: XLS v.s. XLSX
weird. saving the same table as .xls works immediately. Using Office 365.
Re: XLS v.s. XLSX
i am using 365 as well and doesnt matter if i use the "app" or have it installed on my machine locally. It works in all cases.
I could check your files here if you would like me to do so...
dd(at)ventuz(dotcom)
Re: XLS v.s. XLSX
I sent an email with the attached file.
