I'm struggling with combining the Touch Pattern and the Touch Paint Node.
When using both nodes with the ScreenAligned option checked, I get all gesture events of the pattern node and can see the touch-movement-strokes for the hole screen.
I want to use this only on a specific rectangle/geometry.
Thanks for your help in advance!
David
Combine Touch Pattern and Touch Paint Node
u-double-u
Re: Combine Touch Pattern and Touch Paint Node
Hi, what do you want to do? Position and scale a rectangle/geometry and then paint on it?
I want to build a virtual touchpad(appletv remote) which detects touch gestures (swipe left/right/up etc.)and visualizes the touch-finger-movement.u-double-u wrote: ↑27 Jul 2019, 22:48Hi, what do you want to do? Position and scale a rectangle/geometry and then paint on it?
Hey this is made in version 5 quick scene but should apply same way in v6, you can swipe gesture and see the paint effects
https://drive.google.com/file/d/1Vd1fQo ... sp=sharing
Thank you for the scene and sorry for my late reply.hgoodsir wrote: ↑20 Aug 2019, 15:44Hey this is made in version 5 quick scene but should apply same way in v6, you can swipe gesture and see the paint effects
The problem is that i want to use the Touchpattern/Touchpaint node only in a specific area of the canvas(defined trough a rounded rectangle).
