How do I make an imported Photoshop layer into a 3D layer?
I want to be able to move the layers within my Photoshop file in Z space, but at the moment I can only see the option to move them in X and Y in the properties under layout.
Thanks,
Lorna
How to move Photoshop layers in Z space
Re: How to move Photoshop layers in Z space
Hi Jones,
I am at the very beginning of using Ventuz. I have been trying to figure out how can I use photoshop layers in the hierarchy slide node, which is a child of a slide manager. Apparently, I can use the texture or material nodes to create the scene from scratch in every slide node abut I was just wondering If I can use the photoshop layers in the slide node? Otherwise, I can not say I understand the point of having photoshop layers, even though it is possible to animate them, use them as a background etc. Could you be able to find an answer about using photoshop layers in Z space or using them in the hierarchy editor?
Ozgun
Ozgun
Making single layers of a PSD would be so great!
