especially with the new Artnet Node it would be very useful, if we could get an array of pixels out of the colorPicker!
I need ~ 1000 colorPicker in a project to get the pixel's out of a offscreeen render target... is this a performance killer?
Greetings
colorPicker Array
Re: colorPicker Array
I recently made a project that would require something similar.. for that project I made 100 nodes (10x10) and it worked out fine in the end Performance-wise.. but i noticed that if i drop one node in the content My CPU Jumps up a lot.. I'm not sure what "Content Validation" implys but I know that Placing 1 or 100 nodes did not change performance, or at least the difference was not visible.
Dropping 1 color picker node Here: https://drive.google.com/file/d/1OVUTLf ... sp=sharing
i am not sure if this is on purpose since it has to revalidate every frame -
anyway i created a ticket for it and lets see if it can be fixed or at least taken out of the statistics...
RegArts
RegArts
Hi...
forget it... you can do it very easy with the ArtNet Pixel Mapping
Greetings
Greetings
