Hi again,
I could think of the possibility to record some data.
I would like to have a recording of the movement of a tracked device (HTC-Controller) and be able to replay that.
Is that possible already inside Ventuz?
Maybe it could be another node (Rec/Play) in „Interaction“ or „Data“. Drag it to the scene, connect its input(s) with another nodes output(s) and route its output (with filename) to a resulting file, that can be read by the „recorders“ counterpart, the „player“.
Starting of recording and playback could be handled like in the movieplayer, so it can be started/paused/stopped etc via some remote (remoting, OSC, Midi...) as well.
cheers
Feature Request? recording of data in Ventuz?
Re: Feature Request? recording of data in Ventuz?
you could build a c# script for that, should be rather straight forward. Though a feature like that would be nice
hm, I can‘t...
