Movie Stream Problem
When I use Movie Stream to play an rtsp stream, it will stop at about 20 second, and the IsEnabled is false, then it will reconnect, and it will appear repeated.
Can anyone tell what kind of problem could it be ?- Daniel Willer
Re: Movie Stream Problem
Hi there,
I have no idea what the problem is related to. I would try to run the same stream in VLC in parallel to see if it behaves the same or different.
Daniel
Daniel
Thank for reply.
I got the log message when the stream stopped.
Any idea?
Any idea?
Hi there,
Which version of Ventuz are you using.
The error message is coming directly from ffmpeg so there is not much we can do about it.
Daniel
Daniel
This problem occur in Ventuz 5.3.1 and 5.3.2. And I also test the stream in Ventuz 4.8.0, there's no such problem.
Best Wishes
Damon
Best Wishes
Damon
