Hope ventuz implement this feature in future release.if you use shrink 2 fit, that effect obviously changes the bounding box. It also has a parameter for the bounding box type - but it does not output the new bounding box. I'd suggest asking Ventuz support to implement that feature - unless I'm missing something.
Auto resize rectangle size with text length
ahmedahmed1223
Re: Auto resize rectangle size with text length
Thanks Lerou
Right to Left does not matter to Ventuz. Everything works exactly the same in Arabic. Just make sure that you select "RightToLeft" in the Block Text node.
