Connect control of keyframe animation
hi all,
maybe a simple question, but how can i connect the control of a keyframe animation to a keyframe animation inside of a container?
i have attached a simple video. please remove the .zip at the end of the filename
greets
greets
- connectKeyframe.mp4.zip
- (275.04 KiB) Downloaded 263 times
Re: Connect control of keyframe animation
if this is not possible... please move it to feature request
greets
greets
I had same problem and couldn't find a work around either.
Hi christian,
Can you describe what you want to achieve?
Why does the Color Node have to be outside the Content Container and why does the Animation Node need to be inside?
You can still trigger the Animation by exposing the Events inside the Content Container and bind them to the Animation Node's Methods that you can then place on the same Level as the Color Node.
Is this not an option?
Stephen
Stephen
hi stephen,
no, its not an option
it would just help to build cleaner projects.
greets
greets
Almost thought so.
What about the other way around? Placing another Color Value inside your Content Container, binding its value to the Animation and exposing it (thus making it an output) and then binding the Color-Input of your Scene Port to the exposed value? Still an extra Node, but the Animation is inside your Container.
Currently it is not possible to bind Animation Controls downwards because its bound to Animation Channels directly that cannot be exposed (like Node Properties as in the example above). So its purely technical so far - once everyone is back from NAB I will have talk about that to see if its a conceptual problem as well.
Stephen
Stephen
hi stephen,
again: i have no color node! i am talking about nested animations.. i want to connect the control property of an keyframe animation which is outside of a container to a keyframe animation inside of a container.
greets
greets
hi stephen,
i sould start to read till the end
you already gave the answer: it is impossible
but would be realy nice, if it would be possible
greets
greets
Hi Stephen,
I also vote for this feature
Greets, Stephan
Greets, Stephan
