I thought I would list this bug as it seems to creep in with the move to ventuz 3 but it disappeared with the last update I had and now it is back again.
See the attached images where the nodes in the content window appear to go transparent so you can see all the connection lines, just gets very messy and difficult to work with.
Must be something to do with my setup as it came back again?
Also I think the last post I did about moving families (http://forum.ventuz.com/viewtopic.php?f=12&t=956) is probably more of a bug then a feature, sorry should have listed it in this section.
Joe
Connection Lines
- Joe Styles
Connection Lines
- connection lines.png (27.52 KiB) Viewed 4453 times
Joe Styles
Kinetic Pixel
Kinetic Pixel
Re: Connection Lines
Hi Joe!
Does this happen directly after loading a scene or do you have to create new connections in the Content Editor?
- Joe Styles
Hi Karol,
Yes the problem with the connection lines happens as soon as I open the scene. I have attached a copy of it.
As for the problem with moving families, this happens all the time as I think that it how it has been designed to work.
Joe
Joe
- connection lines.vzs
- (8.86 KiB) Downloaded 393 times
Joe Styles
Kinetic Pixel
Kinetic Pixel
Fixed for 3.06.02!
The new Annotations did a strange GDI render-state change!
