Moving Families in the Content window
Joe Styles
Post by Joe Styles » 22 Mar 2012, 13:08
Would it be possible to move a whole family in the Content window even when the items are nodes are collapsed?
How many times have you move a collapesed item then expand it later on and all your nice layout has moved because the other items in the collapsed tree reside in the origonal position then everything moves.. doh!
It really would help keep some of those crazy diagrams in the content widow under control :?
Joe Styles
Kinetic Pixel
Oliver
Re: Moving Families in the Content window
Post by Oliver » 17 Apr 2012, 11:27
hi,
which version are you on, cause if I do this on 3.061 I encounter no problem with it, maybe i got you wrong...
Im moving a whole family while everything inside is collapsed, when I expand - everything has the same position inside the family window as before the move.
Joe Styles
Post by Joe Styles » 18 Apr 2012, 16:39
Hi Oliver,
Yeah I think I have worked out what was going wrong now.. it was down to moving a single node that is part of a family and that family is comply collapsed.
I have attached a sample. If you expand the family connected to that axis, you will see they are all nice and close together. Collapse it again and move it and the other nodes stay where they are. I can see why the content window behaves like this but unless you know to not move a single node collapsed in a family you do end up with some crazy layouts.
Joe
Family Moving.vzs
(5.58 KiB) Downloaded 597 times
Joe Styles
Kinetic Pixel
Robert
Post by Robert » 19 Apr 2012, 12:39
Maybe a solution would be to be able to block the position of nodes inside the content window.
robert
