Renderer failed
Renderer failed
In Designer when I go to full screen I get an error.
"Could not initialize or re-initialize Renderer", it only happens in the designer not the runtime, and regardless of scene, I have tried an empty scene.
Works ok if I use virtual full screen.
Re: Renderer failed
The error happened after 6.5.2 to the latest version
NVIDIA GeForce RTX 2080 SUPER Btw
Re: Renderer failed
Same on my Alienware Laptop with 2080.
Christian
Christian
Re: Renderer failed
Which version we are actually talking off ?
Some more info about your Hardware? Software (Win?)
Thanks in advance
Thanks in advance
Re: Renderer failed
Sorry for the delay I have been away.
The computer is and i9 running windows 10 with an RTX 2080 Super.
The error happened from 6.0.0 and all versions till the latest.
The server will only be used in runtime so not really a problem.
Nathan
Nathan
Re: Renderer failed
Same: The computer is and i9 running windows 10 with an RTX 2080 Super.
ALIENWARE AREA-51M R2
Nvidia driver: 451.67
Greetings
Christian
Greetings
Christian
Re: Renderer failed
Did you check the Ventuz logs or the Windows Event logs?
Re: Renderer failed
Hi Karol
This is the error log when switching:
Christian
Greetings14:52:58.0 Info : Device Selecting Device #0)
14:52:58.2 Info : Runlevels leave runlevel ScreenSize
14:52:58.2 Info : Runlevels enter runlevel ScreenSize
14:52:58.2 Error : MAIN Could not initialize or re-initialize Renderer. Initialize() on Renderer failed! / Eine Ausnahme vom Typ "System.Exception" wurde ausgelöst.
14:52:58.2 Info : graphics setting displaymode 784 x 441 at 60054 / 1000 Hz
14:52:58.2 Error : graphics failed create swap chain, error 80070005 (5)
Christian
Re: Renderer failed
And everytime when i switch between Fullscreen i get a BTHUSB warning in the Windows system log.
Greetings
Christian
Greetings
Christian
Re: Renderer failed
Hey,
i had a talk to one of our Devs who is responsible for the renderers code. It looks like it is a problem by NVidia - which is related to the fullscreen switching. He will still investigate what could cause this problem and if its fixable on our side.
Chances are not good since this is more a drivers related issue than ventuz and we have no control over such behavior.
Since you are working with a laptop and most times you would have an intel and nvidia card it is wise to FORCE to use the NVidia card only/everytime in the driver settings.
regArts
regArts
