Hi ,
what is the best way to get the IP Address of a machine ? and detect change of this address.
The System node doesn't show the IP address.
1- using the OSC Remoting with Remoting Machine Signature ? ( i can't get it working with a OSC input node ? is there a example of how to receive this OSC message ?)
2- Ventuz.Kernel.Remoting.MachineSignaturReceiver , what is the Synchronizing Object properties in order to make this class works in a c# node ?
i need a code example to achieve this .
maybe , i miss a more simple way ...
Mat.
How to get IP Address of a machine ?
Re: How to get IP Address of a machine ?
you can get it easily with a c# script
