deltacast latency
All other topics about Ventuz 6 here.
VincentPix
deltacast latency
Post by VincentPix » 07 Jan 2020, 14:34
hello,
I'd like to know what latency you have with your Ventuz configurations.
I tried with a HD cam plugged directly on the SDI input of the Deltacast 3G elp 20 and I measure 14 frames of delay at 60fps (233ms). This is already too much for lip-sync and on an event IRL we'll have lot more HW in the line (LED processor...).
I don't know if I've something wrong in my config or HW...
Thank you for your feedbacks
Re: deltacast latency
Post by Karol » 07 Jan 2020, 15:27
Hi VincentPix,
could you please post your AV config?
This high latency is very strange. With Deltacast we expect 3-4 frames delay.
VincentPix
Post by VincentPix » 08 Jan 2020, 17:50
Hello Karol,
Thank you for your help
Cam Sony HD NX cam (may be part of the latency on this)
Deltacast 3G elp 20
i7 - 16G Ram
nvidia RTX 2080
Output directly on a monitor
My Vtz config is :
no mip map
I tried with and w/o Low latency (no difference)
and Quality or speed priority (no difference).
Thanks.
Post by Karol » 09 Jan 2020, 16:05
Hi Vincent,
I would like to see the original AV config file (.avc)
I talked to our developer who implemented the Deltacast cards and he told me that so many frame delay cannot be caused by the card as it does not have so many buffers.
VincentPix
Post by VincentPix » 10 Jan 2020, 11:16
ConfigDelta.zip
(993 Bytes) Downloaded 818 times
Here is the config. Nothing really special in it, i beleive.
thank you
Post by chriss0212 » 21 Jan 2020, 15:38
what kind of monitor are you using? If you use a monitor with any kind of processing (like a tv) a delay of 160ms just for the screen is not unusual.
Greetings
Christian
