Render To Disk
Posted: 05 Feb 2019, 12:27
Hi All
Often times clients will require a frame of their logo for print, normally we make these within Ventuz then use the render to disk functionality rendering a single frame. I haven't found a better way to do it. Here s an example of the settings I use:
The issue I have with this is when rendering any frame above 4K-5K Ventuz will crash (is Ventuz blowing through the frame buffer?).
On to the request, would it be possible to have a richer render to disk option for single frames, one which allows for adjustment of DPI, a greater selection of formats (such as psd), and one that allows for much greater resolution?
If this is not feasible or if there is already a way of doing this I am unaware of then I'd love to know more.
-Ciaran
-Ciaran
