bug or featureible....but not touchable!
Posted: 22 Feb 2012, 18:29
a cube with a depth of 0 is visible but not touchable! interactive nodes or mouse over nodes are not reacting on mouse over if a cube has a depth of 0.
chriss
Re: bug or featureible....but not touchable!
Posted: 23 Feb 2012, 09:39
by squiggle
actually if the cube itself has a depth (Z) of zero it's still touchable (works like a rectangle), but if you put an axis-node in front of the cube and set the ScaleZ to zero then the cube is no longer recognized by the touch system. Some sort of optimization, like the (optional) Alpha_Block-property, possibly?
Posted: 23 Feb 2012, 15:56
hi all
thx for all the replies :-)
i think there is no need to fix the problem....my post was more an information for everybody who has the problem that the touch node is not working like expected! i took me some time to find the reason....and maybe this helps the next one to get the result faster :-)
maybe you can make a hint in the help file!
chriss
