A setting to adjust the black level of the non-overlap zone would be very usefull.
As explained on this topic previously :
viewtopic.php?f=21&t=3723&p=7245&hilit=shaping#p7245
R
Soft Edge Blending + Black Level
- shermanpat
Re: Soft Edge Blending + Black Level
I 2nd the re-request of my old request!
-Sherman
Meru Interactive
Meru Interactive
As a workaround... you could use a render Target with a white plane... adjust transparency and make a cut in the overlapping area. not a 100% solution... but maybe better then nothing
the good thing: you could blur the edges a little bit.
Greetings
Christian
Greetings
Christian
