Render to Disk feature for touch scenes
Posted: 06 Jun 2018, 10:14
by _aTom_
Hiho,
is it possible to capture a touch driven scene and render it later to disk?
I need often the screen capturing when i move my scene with a touch transformation node.
Currently i use external tool but they can not capture highres touch scenes with more than 30fps.
Re: Render to Disk feature for touch scenes
Posted: 06 Jun 2018, 15:39
Hi Tom
you can use OBS Studio for capturing in realtime! It is free and can capture directX streams! Very powerfull and free!
https://obsproject.com/de/download
Need some time for configuration... but very nice!
Greetings
Posted: 07 Jun 2018, 09:14
Hi Tom,
do you want to capture in Designer or during Runtime?
Posted: 08 Jun 2018, 14:58
by _aTom_
Hi Chris,
thanks for the link. I will check the tool :)
Hi Karol,
mostly i capture a movie in the designer to show clients how it looks. Presenter Mode would be also good if Its to difficuit in the designer.
Posted: 12 Jun 2018, 09:09
Hi Tom,
in Designer you can record the Touch Interaction with the scene (but only with the scene - not with the Designer UI):
https://www.ventuz.com/support/help/lat ... nderToDisk
Posted: 18 Jun 2018, 12:20
by _aTom_
Hi Karol,
yes i know i can capture interactivity in Ventuz but ...
when i make touch transformation it´s not storing the start position of first touch i did. It starts with my last position.
I can make a reset position but thats not very helpful mostly. Maybe its just the option to store the start position of the Touch Transformation what makes the difference :)
Also it would by great to capture optional the full ventuz screen with the Designer UI.
Best regards,
Tom
