Is there any reason, why it is not possible to connect the Input of the ProjectData to a value? Sometimes it would be very helpfull if we could do so.
Thx and greetz
Christian
ProjectData
Re: ProjectData
do you mean to send into the project data....or to take from project data....i think what you want to do can be done with scene data...
Re: ProjectData
yes, but if you have several different scenes (30+) per project which share the same data like Network configurations for example it would be great to access from every point inside your project and alter them from a single point inside the project.
Of course it is possible to spread the data in different ways (scene data is one of them) but project data would be the simplest solution from our point of view. But for now it is hardly possible (c# script opening a cluster, accessing project data) to use it because you can't change the project data from a node directly.
regards, Eric
regards, Eric
