I was playing around building some content with the aim of controlling with Director. All fine but in my scenes I notice that a graphic moving across the screen is not in sync between what I am seeing in Director output and what I am seeing on the main cluster output. I then put a mover in the scene and output to a text node. There is about 3 seconds difference between the two machines.
Should it be in sync using the cluster clock or is that only between clusterered outputs?
Sync between Director & Display outputs
