I am having an issue with setting up multiple displays with touch screen.
So I have a project with two displays, one of which is a touch screen and another one is not. I want to be able to push content from one screen to another with touch translation.
All works fine in ventuz, but the problem is making a mosaic display using Nvidia. Since I have two (1920x1080) displays and merged them into one 3840x1080 display, My touch is actually not mapping properly. (for example: if I touch pixel 300x500 on my touch screen, the mouse courser is actually on pixel 600x500 (double width)). The issue about this is that We cannot make a VPR file run on "extended displays" i can only make it run on one merged Mosaic display.
So my question is.. Can I change the ventuz 5 configuration to run a VPR on two extended displays [1][2] rather than one merged displays [1/2](mosaic).. but still only using one machine ??
Touch Screen setup
Re: Touch Screen setup
Hi!
What you need is currently not possible out-of-the-box.
It will be with Ventuz 5.3!
I had the same problems some time ago. I Look forward to V5.3 for Ventuz solution, but in the meantime this may be a solution for you
http://touch-base.com
as it allows you to re-map the touch area. I haven't tried it under V5 but it certainly worked under V4. You choose the make of touch screen you are using and download a test driver that allows a few touches for testing. If that works you can purchase the proper driver from them. Not expensive!
Thanks to both of you, I will try the software, I've been looking for something like that actually.
Also Karol do you know approximately when ventuz 5.3 will be released?
