Does V5 license work for V4?
Posted: 21 Jul 2016, 11:13
by pasto
Hi all.
Can I still work with V4 once I update the license to V5?
(I mean not to open V4 prjs with V5 but to use V4 software)
A.
Re: Does V5 license work for V4?
Posted: 22 Jul 2016, 15:06
by dpaniego
You can run version Ventuz 4.07.02 or newer with Ventuz 5 license, if you have the new dongles - the round shaped ones with a red band in the middle.
If you have the old black, square shaped dongles, you can run both v.4 and v.5 depending on the licenses you have enabled.
In any case, most V.4 projects should be fully compatible with V.5.
Thanks,
David Paniego
VENTUZ
