how to extract an array of values from a Spread node?
Posted: 29 Apr 2016, 14:38
				This is what I have so far:
A spread node, under it a Simple sphere.
What I have changed in the input property of the Spread node are the following:
Position X: 1.3
Position Y: -0.5
Rotation X: -13
Rotation Z: 6
Spread Max: 20
Spread Count: 20
what I am trying to do is somehow extract some sort of array of values from its output Property. plug it in to a float array, and finally drive a line chart value property by the resulting float array.
The step i am having problem with is the extraction of an array of value from the Spread node to the float array.
Hope this helps. any insight would be much appreciated. Thank you
Position X: 1.3
Position Y: -0.5
Rotation X: -13
Rotation Z: 6
Spread Max: 20
Spread Count: 20
