I can't find the BlurTexture Simple in Ventuz5
Posted: 22 Apr 2016, 21:46
by kberraho
Anybody know where i can find the Blur Texture Simple in the toolbox. Thank you
Re: I can't find the BlurTexture Simple in Ventuz5
Posted: 24 Apr 2016, 10:17
by Olivier
Hello!
I had the same problem : looking for V4 nodes that are working fine for what we want... Like blur texture, render target, viewport backgroup etc etc.
Just open V4 and copy the nodes you need and then paste them in V5
Posted: 24 Apr 2016, 16:18
by ErikB
Just be aware that those nodes are not meant for use in V5 (which is why they are hidden), but are only there for backwards compatibility. You can do all of those things through layers more efficiently, because you can output the content of a layer to a render target in v5. if you find something you cannot do, but could in v4, let us know.
Posted: 25 Apr 2016, 10:29
by Olivier
http://forum.ventuz.com/viewtopic.php?f=43&t=4222
Erik : We have some problem using the slide manager... I'm working on a show made with the slide manager. I want to put all my stuff inside it. So everything is inside one slide... I need to blur text sometimes or images, put 3d object etc etc but I need the easy way of copy, paste, auto in and out that gives the slide manager... And I can figure how I can use multiples layers controled by a slide manager...???
Posted: 25 Apr 2016, 13:21
by kberraho
Thank you for your input i will go ahead and use the layers to achieve the same affect. Thanks again.
Posted: 25 Apr 2016, 15:53
by ErikB
Ah Olivier, okay, that makes sense.
And no the Slide Manager is actually kind of outdated itself, so it really doesnt work well with the Layer system. We are working on that problem though, stay tuned.
-E
Posted: 16 May 2016, 14:33
by s-petersen
ErikB wrote:Ah Olivier, okay, that makes sense.
-E
PLS don“t do it.
i used the slidemanager a lot.
its easy and fast way to compose presentations!!!
