How to animate a bar graph using an audio Feed node
Posted: 15 Apr 2016, 19:46
by kberraho
I have set up my node using an array indexer however i am having problem getting the frequencies to show up before i hook them up to an array, Any idea? Thanks
Re: How to animate a bar graph using an audio Feed node
Posted: 17 Apr 2016, 13:35
by joysprod
If this is not working for you, I would guess that you have not set up the audio cross points in the Ventuz configuration. By default the node does not respond to audio. Have a look at this...
http://www.ventuz.com/support/help/late ... lysis.html
I know the link is for version 4, but the same for V5.
Posted: 18 Apr 2016, 13:54
by kberraho
Good morning,
Thank you for your reply, I followed the link you sent, however when I go and try to save it and I go back to the Config editor main page, for some reason I am not allowed to select the new Mapping i have created, it remains on (None), any suggestions would be much appreciated.
Here is a screen cap
https://we.tl/fu3L1fukdF
Posted: 18 Apr 2016, 15:14
by Olivier
I think because you can't change it while Ventuz is running... Stop all Ventuz apps, open Configuration Editor, select your Layout etc etc...
Posted: 19 Apr 2016, 13:53
by kberraho
Wow I feel dumb now, Thanks for the tip, it did work. CHANGE THE Config after closing Ventuz. Thanks again. really appreciate it.
