I 'm using a thin and normal custom font into an entriched block text.
When I setup my fonts as references it's working properly whilee doing this kind of text : "<Bold>BLABLA</Bold>, A SUCCESS"
But when I'm importing the fonts into the project, all my text is changed to the Default font, since I start to tap the "," in my input.
Hope you understand me.
Thank you,
Olivier
Font problem
Re: Font problem
Hi Olivier!
We discovered this problem recently!
It's currently not possible to use multiple not installed fonts in the EnrichedBlockText node.
We will try to fix this for Ventuz 5.0.2.
The only workaround now is to install the fonts you need.
Re: Font problem
I am also having a problem with the Enriched text box.
I have installed an additional font from the custom model, this worked the first time it tried it, but now I just see corrupted text where I want the alternative font.
Nathan
Nathan
