Ventuz Touch
Posted: 26 Feb 2016, 10:49
Hi all.
I have many concerns for missing important nodes for the touch system in Ventuz which will help us to accomplish things with minimal efforts,since some of us are artists more than programmers. The problems I am having are the following:
1- Touch ripple is very sophisticated. I can't track where the person touched first. Sometime two values change together, one holds the last value ... even tracking with pressure was hard for me... I just couldn't grasp the logic of it yet (although I am a programmer). I would like to have a very very simple node that gives me the coordinates of the first touch on the screen, and always . . No cycling etc . . . as simple as that.
2nd : I would like the touch transform and zoom to work as it should work like all programs do ! that is: where you touch must be the pivot point of the Zooming. Ventuz always zooms only from the middle. And since touch ripple has sophisticated logic, I might never accomplish to assign a pivot to the object I am zooming (definitely Picture like newspaper show).
3- Please, if it is possible,please add an old value field with the A,B,C ... . Is better then always using loop breaker.
I would appreciate a lot if any of these would be accomplished. But PLEASE I would like to get a way for zooming the picture. If you already have a solution please post it, so that we learn from it.
regards,
KEEP UP THE GOOD WORK ! VENTUZ !
regards,
