AMD Eyefinitygroup cluster building problem
Posted: 30 Jan 2016, 18:51
by stephan
Dear community,
I never had problems in cluster building in the past. But from now on ...
Building a fresh win7 system (updated till end of 2015), graphicscard AMD W8100, last firepro-drivers, eyefinitygroup (3x1920)x1080.
Everything's fine.
The Ventuz-Configmanager (v.4.07.01) don't accept this eyefinitygroup and shows the attached errors
( ... one ore more elements in the cluster have a zero resolution ???)
The created layout is 1x 1920x1080.
I have no idea what to do ...
thanks in advance for your help,
Stephan
Re: AMD Eyefinitygroup cluster building problem
Posted: 30 Jan 2016, 20:08
by stephan
... forgot to say, can't create the following render-setup because of hang-up (freeze)
Posted: 31 Jan 2016, 10:23
by stephan
Problem solved, but unknown reason for mailfunction ...
Building an identical system this night, same hardware except the graphicscard (W9100), and it's ok
The Configurator works as expected, can build displaygroups.
Very strange, I can't explain myself ... it must be a hardware problem, Ventuz is innocent
Stephan
Posted: 01 Feb 2016, 09:16
by stephan
... the mainboard is the killer
Both systems uses absolutely identical asus mb's, one system works, the other not.
It's better to give up any search for a reason
Stephan
Posted: 01 Feb 2016, 09:44
by lerou
I just set up a test cluster with an Eyefinity group - used consumer GPUs though. Same issue: Ventuz Config couldn't retrieve the info from the system. I just set it up manually and it works. The error pretty much only means your system doesn't report the display config correctly for some reason. I wouldn't assume any hardware error. Although I don't know about your freezing issue.
Best,
Posted: 01 Feb 2016, 10:59
Lerou is right!
This error message only means that Ventuz Machine Service (VMS) could not retrieve any valid display setup information from the graphics board (could be related to the driver version or a bug on our side).
In such a case you have to build your RenderSetup manually.
BUT this does NOT affect the functionality of the RenderSetup rendering in Ventuz. This automatic RenderSetup build is only a convenience feature.
Posted: 01 Feb 2016, 12:34
by stephan
Thanks guys for answering,
the problem is freezing after closing the popup-menu, so I could'nt setup render-settings >CTRL-ALT-DELETE ...
Stephan
Posted: 01 Feb 2016, 12:37
by lerou
Now that's something for the Bug-Forum
Posted: 01 Feb 2016, 13:22
by stephan
that's something for the recycling-hof
