Images from ftp
Chris
Images from ftp
Post by Chris » 08 Jan 2016, 09:29
Hi All,
I'm currently trying to load images from an ftp folder, using the URL node via a DIR node (to enable searching through the folder contents.
Can't seem to get the texture loader to load the image, it just shows an error saying it can't load the texture.....
The connection to the ftp seems ok as the url string on output is correct.....
Is it better to script something to pull the images and save them to a local folder??
Can anyone post a quick example? Not sure if I'm missing something simple.....
Chris
Chris
Re: Images from ftp
Post by Chris » 08 Jan 2016, 22:28
If I connect the URL to the Directory I get this error:
21:00 08/01/2016 Error : DIR (Directory): Could not scan folder: The given path's format is not supported.
If I connect the url directly to the Texture Loader i get this error:
21:00 08/01/2016 Error : TexLoader (Texture Loader): Failed to load Image: ftp://username:password@ftp.website.com ... icture.jpg: The remote server returned an error: (530) Not logged in.
Would the log in issue be on the ftp side?? or windows? or have i input the information wrong in the URL node??
There is a quick example of the basic setup attached. Have i done something wrong or should this be working??
thanks
chris
ftp images.vza
(7.91 KiB) Downloaded 419 times
Chris
Re: Images from ftp
Post by Chris » 11 Jan 2016, 15:16
Anyone???
All the details I'm inputing seem correct yet this just does not work.....would it be better to script this?
I was possibly thinking of using a third party app to download content from the ftp and then just use local drive links for the images......is this a more reliable way of acheiving this??
Chris
u-double-u
Re: Images from ftp
Post by u-double-u » 13 Jan 2016, 00:37
Hi, I can imagine that the problem might come from "active" versus "passive" ftp.
cheers
Uwe
