Multi display out with out Display Group?
- shermanpat
Got a simple project I am working on that I plan to be hosted from small touch screen computer for user input, then has a external monitor with data.
What is the best way to have a Ventuz scene to display across both displays when the GPU doesn't support Display Grouping (Mossiac, Eyefinity).
Thanks for the input!
-Sherman
-Sherman
-Sherman
Meru Interactive
Meru Interactive
Re: Multi display out with out Display Group?
if the GPU doesn't support display groups, you're limited to a single screen. Switch the GPU (Consumer AMDs support this) or use a second machine.
Best,
Best,
may be this is a solution for you:
http://www.matrox.com/graphics/de/produ ... splayport/
or this:
http://www.matrox.com/graphics/de/produ ... o/digital/
or this:
- shermanpat
Yep I have used plenty of the Matrox and or data path solutions. Each works well in its own space.
But what I am really looking for is a laptop the I can use the local display and external displays as one group to be used by ventuz.
Anyone have suggestions on a machine that might work? Razor? Other gamer or workstation machines that would work?
-Sherman
Meru Interactive
Meru Interactive
O.K. Now I understand you
Then you must have a laptop with AMD's mobile solution, like AMD Radeon R9 M265X or AMD Radeon R9 M375
Then you can built with the eyefinity technology a single desktop. This should work.
I only find notebooks on the quick: Lenovo IdeaPad Z51-70 and Toshiba QOSMIO X70-B-110
For Nvidias mosaic technology you need Quadro M500M or something else, but it is more expensive.
I don't know how much power your application needs...
found this: https://www.youtube.com/watch?v=_Rj4EYWxMBs
HP Z workstation notebooks have options for Quadro based GPU's that support Mosaic. If you need a lot of GPU power though they can be quite expensive.
- shermanpat
Thanks for the input, I will keep searching.
Side note:
I am here testing the new Microsoft Surface book, ventuz config doesn't even see the Nvidia dGPU only the Intel HD520. Sad, but I knew this machine wasn't going to work the this set up. I had better hope for it than this...
Side note:
-Sherman
Meru Interactive
Meru Interactive
We do not have the Surface Book here but probably you have to configure somewhere that the Ventuz Config Editor should run with the Nvidia card and not the Intel onboard graphics.
This is usually necessary if you have a hybrid graphics laptop.
Sherman,
little trick with the surface book: you can install the nvidia GeForce Experience software, which will allow you to select the default GPU for applications. Just set up Ventuz to start with the Nividia GPU by default in their control options (right click on desktop > Nvidia Control Panel > Manage 3D Settings, switch them to High-performance Nvidia Processor), and it works.
