hi
i have a scene with a movie clip node that connected to a dirctory with lots of files.
these files needs to be updated on the fly so i used the "Enabled" feature on the movie clip node to allow windows to delete/replace items in the folder so its not being used.
this scene works great as standalone and everything else works great until i use this scene in a bigger scene using "Scene port".
when using the Scene port node with that scene the Enabled feature dont work anymore, i can even see it being used in the statistics Movies view.
kinda strange to me and i have no idea what to do.
any help will be appreciates
thx
movie clip node dont allow to delete file
Re: movie clip node dont allow to delete file
HI there
Can you please post a simple sample scene that reproduces the behavior.
Daniel
Daniel
hello again
sorry it took me so long...
ive attached an archive and the scene you need to use is "UI 7.1"
the ui wont work correctly because u need some XML files but its not in English anyway.
inside the scene u will find a switcher called "current scene" and inside that switcher the problematic cases are 5, 6 and 7.
i REALY lost on that one and truly need help!
thank you very very much.
here's the link -
https://www.dropbox.com/s/j0u2vibmsig4s ... i.vpa?dl=0
here's the link -
