this is not a big one... but it cost me a moment to figure out what's going on, so I'll annoy the forum in return.
Create a new empty scene
Create a touch translation node, followed by a rectangle. Set the touch limits:
active: true
MinX = 0
MaxX = 0
MinY = 0
MaxY = 10
Move the rectangle up a bit
Set MaxY = 0
Hit reset on the touch node
Increase MaxY
You'll see the rectangle move up. Seems like the reset was ignored while the y-limits were both at 0. Probably ignored as y-movement is more or less disabled with such values. However if you're setting the limits from some other node and they become 0 during a reset or so, this might confuse you the way it did me
cheers,
