Live Video feed freezes while SQL Fetch
Posted: 16 Dec 2014, 19:58
by rusDXB
Hi all
i have quite simple setup
Live feed on the background (Texture)
several text blocks and image loaders over it.
Fetching content into it using query mode, every time I'm sending the query the live feed freezes till data received, which is around 1-2 seconds. I saw the asynchron tick on Properties panel of the query but it seems it does nothing.
Any ideas of how make it to work together.
Re: Live Video feed freezes while SQL Fetch
Posted: 18 Dec 2014, 13:12
by Daniel Willer
Please check the Asynchron flag on the Query node to not interrupt the rendering during the query.
Posted: 18 Dec 2014, 13:37
by rusDXB
Hi Daniel , as I mentioned in post , switching the Asynchron flag on , doesn't make any difference. Any ideas ?
Posted: 18 Dec 2014, 14:02
by Christian Krix Schmidt
I can confirm that there is something not working as intended. We recently had a project with a SQL database connected and loads of twitter feeds. The Query did cause a render stall even though it was set to Async. This did not happen diring production vecause we did not have that much data. But during the show the amount of data caused frame drops. We had to move the data query to another static part of the scene to avoid visible frame drops.
Posted: 18 Dec 2014, 15:06
by rusDXB
Thanks Christian , I resolved my event by using RSS node, but I still want to make SQL work, it has more power into it.
Posted: 19 Dec 2014, 12:37
by Daniel Willer
Ok we will double check that over here.
But that is not gonna happen before next year.
Daniel
