Content merging makes some connections invisible
Posted: 27 Nov 2014, 09:54
I just found a way to reproduce a bug that we sometimes observed.
How To:
I believe the merge functions somehow skips the variable and connects right to the source, but since the source is outside the container the connection cant be displayed.
Greets
-Schub
How To:
- Create a content container with a variable in it
- expose the variable input and connect it to something outside the container
- back inside the container, create a node (e.g. expression) and link its input to the variables input (so that the input is used like an output)
- merge the last created node with Ctrl+M
- Result: the connection to the variable becomes invisible, both nodes act as if they're still connected
Greets
-Schub
