Datetime Node
Drac Zhang
Datetime Node
Post by Drac Zhang » 19 Nov 2014, 09:07
When I use Datetime Node I found that it's so unconvientent to do some calculate, such as add some minutes.
So does it possible to add something to do it in the node?
Drac Zhang
lerou
Re: Datetime Node
Post by lerou » 25 Nov 2014, 12:06
DateTime is very simple, use a script and put out whatever you need. See here for string format examples, here for documentation.
See attached vza for Ventuz example.
cheers,
DateTime.vza
(6.07 KiB) Downloaded 505 times
Drac Zhang
Re: Datetime Node
Post by Drac Zhang » 26 Nov 2014, 05:19
Thanks for answering.
I know C# script can do this things. But I want to refresh the time every second I have to use a script and a datetime node to validate the new time.
So I think if the datetime node can do this, it will be much more convient.
Drac Zhang
Eric_RD
Re: Datetime Node
Post by Eric_RD » 05 Dec 2014, 17:42
You Can do that with a simple string Expression.
Create a string Expression with the following inputs:
DateTime, string
Day, int
Hour, int
Minute, int
Second, int
insert this for the Expression:
Convert.ToDateTime(DateTime,new System.Globalization.CultureInfo("en-US")).Add(new System.TimeSpan(Day, Hour, Minute, Second)).ToString()
Now connect the DateTime output of the DateTime Node with the DateTime input of this Expression.
You can now set positive or Negative values for Day, Hour, Min and Second
I'm not sure about the Cultureinfo. Even my System is Set to DD.MM.YYYY (and the DateTime Output shows it that way) it arrives at the String Expression as MM/DD/YYYY so you have to convert this.
