Output Rotation
Posted: 13 May 2014, 06:25
by joysprod
Is output rotation on the V4 roadmap? I have a requirement to build an 8 output system with screens set at 0 and 90 degrees arranged with various offsets.
Re: Output Rotation
Posted: 16 May 2014, 23:18
by shermanpat
2nd that question.
I have seen in the layout config that there is a value showing rotation but have not seen where you can edit it.
Also with out trying to steal this thread(was just about to ask this question as well). Might you be planning a way to map different sized screens by use DPI or physical size in the layout config with out needing to use the shaping?
I have a client that wants to use 3 different sized monitors also at 0 and 90 deg rotations for one wall all receiving 1080p.
Thank you.
Re: Output Rotation
Posted: 19 May 2014, 14:30
by ErikB
Both of these are known and on the roadmap, but we're not sure what the schedule is for implementing them yet. We briefly had rotation in there, but it created some serious problems we hadn't anticipated, so that needs to be sorted first.
-E
