General question on Ventuz (import geometry, groups, etc.)
Posted: 21 Apr 2014, 15:34
Hello, I'm not familiar with Ventuz, could you help me to understand how the following works:
1. Are there any standard UI elements, such as buttons, checkboxes, lists, etc.?
2. There is a 3D model, which consists of several groups of objects. The task is to perform some action at clicking any of the groups (show data about the group). The model is imported from a *.dae file (the object hierarchy is preserved). Is it possible to write a click handler, so that there is no need to apply it to each of the groups? (To subscribe several elements to one and the same event and get information about the event initiator). For example, there is a 3D shop model. It is necessary to show information about the shop, which was clicked. It is rather clear how to make it, if a separate logic for each shop is written, but is there a possibility to write a general case for all shops at once?
3. Massifs with dynamic size: Is it possible to change the size of a massive after it was created?
4. If a picture is overlapped with a small-sized rectangle, white colors will prevail on the picture?
5. Import of a *.dae file is made incorrectly, if transformation was applied to the groups (the *dae file was received by conversion of *.max file from the workshop).
6. In which way is it possible to implement such a control as a carousel with a dynamic quantity of objects (is it possible to implement a list with a dynamic number of elements)?
