SQL Query Stored Procedure
Nicklt
Post by Nicklt » 15 Apr 2014, 11:36
Hi guys,
I'm building a data driven presentation at the moment and some of the database tables I would like to return are using stored procedures. Have not had any luck getting one to work at the moment though, so thought Id ask whether or not the SQL Query Object supports providing a Stored Procedure Name to execute the query.
Nick
Daniel Willer
Re: SQL Query Stored Procedure
Post by Daniel Willer » 06 May 2014, 10:52
Hi there,
I guess we never tried out by ourselves. I will write a Ticket do a test for it. Do have a simple example that shows the probleme.
Daniel
Götz_B
Post by Götz_B » 16 May 2014, 13:18
i did some tests with Stored Procedures and our Query Nodes. It works fine.
In the Query itself you might have to respect the specifics of the database type or the SQL-dialect you are using. Also don't get confused by the SyntaxError Messages in the Script Editor. Hit Save&Close and check the Message Log for Errors.
I attach a small scene that uses the database from the helpscene for the Database Node.
Regards,
Götz
DatabasePro.vza
(28.82 KiB) Downloaded 1015 times
