Ventuz installed on Surface Pro
Posted: 09 Nov 2013, 18:15
by alfred
I plan to try to install Ventuz Designer or Runtime on Surface Pro, the os is Windows 8 Professional, with i5 dual core cpu and 4GB SDRAM and intal HD4000 onboard graphic card. Is it must be a specific version of Ventuz for Surface or not? In addition, can Ventuz be encrypted without dongle, but a key. Otherwise, Surface will have a tail, looks a little bit ugly
Alfred
Re: Ventuz installed on Surface Pro
Posted: 09 Nov 2013, 18:41
by Christian Krix Schmidt
You won't need a special version of Ventuz. The Surface Pro is essentially nothing more than a regular PC with a touchscreen ... granted ... a very small one.
There are software licenses only for Ventuz. Get in touch with Ventuz. They will help you out. In the meantime you can check out if everything works like you want using the PLE version. Just download the latest version and run it on the Surface Pro. The PLE will have a watermark but everything else works 100%.
Posted: 10 Nov 2013, 01:20
by alfred
A sonic respond
Thank you so much, Christian!!
Alfred
