deltcast input turns white.
Posted: 12 Oct 2013, 02:39
by davidkmiller
sometimes when going from windowed to fullscreen or dragging from one monitor to the next one or more of the inputs on deltacast will just turn white and it becomes impossible to get a feed without a full system reboot. Any clues. tried reinstalling drivers....no luck...sometimes when i go full screen a feed that wasn't working will start working and a different feed will turn white..
Re: deltcast input turns white.
Posted: 12 Oct 2013, 05:40
by shermanpat
10:34 PM 10/11/2013 Debug : videoengine: stream 5: recreate video buffers on interface
10:34 PM 10/11/2013 Debug : videoengine: stream 2: recreate video buffers on interface
10:34 PM 10/11/2013 Debug : videoengine: stream 4: recreate video buffers on interface
10:34 PM 10/11/2013 Debug : VFontGenerator: Generated Texture Font for Lucida Console successfully!
10:35 PM 10/11/2013 Debug : videoengine: stream 4: recreate video buffers on interface
10:35 PM 10/11/2013 Error : deltacast: clock system mismatch. try to open 1000/1001 while 1000/1000 is already running
From Dubug log
Posted: 12 Oct 2013, 16:01
by davidkmiller
8:51 AM 10/12/2013 Warning: Machine: Creating default Machine Config
8:54 AM 10/12/2013 Warning: Decklink: Too many Audiosamples in frame. max 800 expected, 801 found. This warning will only display once
8:56 AM 10/12/2013 Error : deltacast: videopipe\deltacast.cpp(2519): error 31 (0x1f)
8:59 AM 10/12/2013 Error : deltacast: videopipe\deltacast.cpp(2519): error 31 (0x1f)
Posted: 13 Oct 2013, 16:41
by davidkmiller
seeing this error
always accompanied by a WHITE video stream
Posted: 14 Oct 2013, 09:32
by Dierk Ohlerich
The error message indicates that you are mixing video signals with 1000/1000 and 1000/1001 clocks, like 60 and 59.94 Hz. (or 50 and 59.94 Hz). Deltacast cards can't handle this situation. I assume you have two inputs that are set to autodetect. I would suggest you try set them manually to the expected video format as a quick fix.
What video formats are you trying to receive? I would like to reproduce the problem here and make Ventuz behave better. But there seems to be also a Deltacast driver problem. Restarting Ventuz should be enough to get things running, a reboot should not be required.
Posted: 15 Oct 2013, 14:41
by davidkmiller
Thanks for the response! I think you are hot on the trail. I swapped cards to the Black magic decklink and immediately saw some refresh rate mismatch errors. I corrected on the Blackmagic and it has been working flawlessly. I am on show call the next week with the Blackmagic solution which will get through the week when i get back to the lab next week i will retest the deltacast with the suggested settings.
Posted: 15 Oct 2013, 14:43
by davidkmiller
inputting 3 devices at 720p 59.94 and one at 720p 60. Was set to auto detect. With the blackmagic i manually entered all inputs.
Posted: 19 Oct 2013, 21:48
by davidkmiller
was able to confirm that this was caused by attaching an output device that defaulted to 59.94hz while my input devices were all 60hz standardizing the refres hrates on input and output sides seemed to fix this issue
