hi all
i found this shader which is pretty cool....but if i put an alpha node in front....alpha is not blending ;(
at the moment my workaround is using a render to texture node...but maybe there is another solution?
maybe somebody can help?!
shaderHelp
shaderHelp
- BlurShader.vza
- (789.22 KiB) Downloaded 551 times
GlareTechnologies
Re: shaderHelp
Hi Christian,
nice shader, indeed.
To enable Alpha you need to modify the HLSL code a bit.
First Add this:
Beside that you maybe need to set AlphaBlending node with alpha blending parameters manually, but in my test it worked out of the box.
Regards,
Glare-Technologies
First Add this:
float Alpha
string SasBindAddress = "Ventuz.Material.Alpha";
>;Code: Select all
c=c/kk;
c.w *= Alpha; //Add this line
return c;Beside that you maybe need to set AlphaBlending node with alpha blending parameters manually, but in my test it worked out of the box.
Regards,
Glare-Technologies
Re: shaderHelp
wwwwwoooowwww!
and glare did it again
thx to my shader pro's!!
