OSC input problem
Posted: 15 Jun 2013, 02:02
I´m trying to control the Z axis on a Ventuy file throughout a Incremental counter, that would make the object move back and forth depending on how the counter is turned. I manage to pack the info and send it via OSC modifying a bit the programms code, and I know it´s recieved "correctly" in Ventuz because I have an error when the Integer is to hig/low. The problem is that the counter doesn´t give negative values and I suppose this might also be a problem to move it in the axis, but neither way I would like to see if you could give me some feedback of what I´m doing wrong or how I could get it to move or recieve the info correctly. I attach a photo of the sw of the counter, on the back you can see also the code used to pack into a bundle the counter info and send it to the "/COUNTER" variable I´ve created, and also a screenshot of the workbench I´m trying to work with.
Thanks in advance.
Thanks in advance.
