Remoting with C#
Posted: 26 Mar 2013, 11:24
by Silvio
I use this code to remote with c# (Visual Studio 2010) ton Ventuz 3
if (this.tb_IP != null && this.tb_IP.Text != null && this.tb_IP.Text.Length > 0)
                this.ventuz_default = RemoteScene.Connect(this.tb_IP.Text, 19200);
            if (this.ventuz_default != null)
                Console.WriteLine("Verbunden!");
try
                    this.scene = this.ventuz_default.LoadScene(this.tb_SceneName.Text);
                    if (this.scene != null)
                        this.ventuz_default.Ports[0].SetScene(this.scene, 0, null);
                        this.ventuz_default.Ports[0].SetActive(true, 0, null);
                catch (Exception ex)
                    textBox1.Text += "Szene konnte nicht aktiviert werden: " + ex.Message + Environment.NewLine;
When i use localhost with 127.0.0.1 it works perfect. But if i run the program on an other pc and use for example 192.168.2.42 it didn't work.
Any Idea?
Re: Remoting with C#
Posted: 27 Mar 2013, 10:32
by Oliver
have you pinged the machine?
